- Joined
- 22 Apr 2018
- Messages
- 124
- Reaction score
- 3
- Country
Perhaps an odd question, mostly I seem to stumble across two different approaches when looking at tutorials on how to build a timber decking:
A. Several posts, joists bolted to posts and decking boards laid on top of joists
B. Fewer posts, few beams bolted to posts, several joists laid at 90 degrees over beams, decking boards on top.
Of course with approach A you most likely save money on timber, however you spend more time digging holes for posts; viceversa with approach B.
Is there an obvious winner? Or does it really all depend on how cheap is labour / timber?
Specifically in our scenario, for most of the decking area we have a high clearance between ground and decking level (3 to 5 feet). Probably 25% of the area has a low clearance ( 0.5 to 2 feet) and a concrete ground. The overall area is probably 45 sqm
