Timber frame below ground level - issue?
5 Dec 2012
I'm building a log cabin base and i need to log cabin to be level with the current paved area, due to planning permission and not exceeding height.
Therefore, i am excavating a bit of ground and installing a timber frame using 6x2 treated timber, so that the log cabin will sit on top of the joists, therefore being level with the concrete as is. This means that the timber will be below the ground level.
Does this pose an issue? Would you put a Damp Proof Membrane on the ground underneath the joists, with gravel covering so to keep it in place? Also weed control underneath the DPM?
cheers
The ground level will be wherever you build from .Need more detail ?
Hi, imagine the back yard, half of which is decked, and half is concrete. The decking is raised 25cm above the level of the paving.
I am building the timber frame where the decking is, so i will be removing the decking and due to planning, i am having to dig down enough to ensure that when i build my timber frame for the log cabin, the top of the 2x6 timber will be flush with the remaining paving in the yard - therefore the log cabin will sit at the same level as the paving, but it will be resting on a 2x6 frame that is below the level of the paving
Hope this makes it clearer.
Will this pose an issue in terms of damp? The timber frame will be resting on timber pads on top of a paving slab
