The bottom part of the gable end wall needs replacing in our timber framed house.
The sole plate, and the bodged layers of brick underneath also need replacing.
The house has 2 45 degree angled beams running from centre to each side.
It has uprights running up to these of 4"x2" which we can replace, the question is this:
We need to replace the bottom part of the 45 degree beams and also the 2 4"x3" center beams and the 4x2 running up to the angled beams on the wall. We need to replace about 3' upwards from the sole plate of them.
What join would be best to use? Some have said a 45 degree for the uprights? whats about the joint for the 45 degree beams?
Pic should explain it better than my words have struggled to do!!!
Straight lines show where we can attach the uprights directly to the angled beams, the zigzag lines are the ones we are unsure of..
*Stops rambling*
*Stops rambling*
