- Joined
- 2 May 2019
- Messages
- 2
- Reaction score
- 0
- Country
Hi there,
I'm planning on building a 14 x 21ft timber framed workshed in the back garden and could use your advice or recommended resources for this project.
The land slopes down 50cm from left to right (looking at it head on), with the right side against neighbours fence.
If I go from the highest ground on the left and level the building, it means that the height on the right will be 2.9m from ground (which means nearly 3m against neighbours fence and back fence which is owned by the local authority and not within permitted planning).
If I excavate the ground on the left to level with right, i will potentially need to build a retaining wall.
Is it a good idea to build a retaining wall and have my pad footing, plinth and 2x6 timber (waterproof coated) and DPC membrane butted right up against it?
Or am I creating more work than i need to and could just dig out the depth of foundation pad, plinth, 2x6 floor and ply (33cm) and leave the soild as it is?
