I'm building a glorified shed/outbuilding and wondered if the timber posts are OK to be 2 x 4s - doubled up at the corners and round the door frame.
It's single skinned brick dwarf wall up to 825mm then about 1200mm uprights in timber to the roof plate. The roof will be clay rosemarys so I wanted to know if 2 x 4's were sufficient.
Would you go for 4 x 4 timber posts on the corners instead?
