- Joined
- 11 Dec 2018
- Messages
- 1
- Reaction score
- 0
- Country
Hi
I'm looking at replacing current single pane wooden sash windows with new, double glazed units and want to be sure I'm making the right choice as it will obviously not be cheap and I want hear to last a long time!
The choices I have are from Company 1: European Redwood or Meranti hardwood. This company plays both of these would be 'engineered timber' and are treated using the TEKNOS system, which apparently means the frames are "dipped in primer and sprayed with very hardwearing micro-porous paint prior to being assembled which is important as it prevents cracking like you would find with a window that comes primed and then painted on site".
Company 2 will make the frames from sapele wood, but the finish would be a primed frame and probably painted on site i.e. the exact method that Company 1 suggests you should avoid!
So my question is, is it all about the wood (In which case I guess I go for sapele) or is the finishing/painting method just as important?
I should also say that there isn't a huge difference in price across all 3 wood options, so cost wouldn't be the deciding factor.
Thanks for any help!
