Ok, not much luck on the m12 bolt issue!
How about Timberlok or Wickes Timber drive screw for attaching joists to the ledger board (outer frame) and joists to the support posts?
I'm thinking of using 7mm x 100mm
Two to each post and two to each joist.
On areas where the ledger board is against the house I would skew screw with two each side.
Does this sound OK?
Does this sound OK?
