Can anyone please recomend a external timer for ravenheat white star as dont wish to use interal clock what is the best make to use and does anyone have wiring diagram for boiler.to wire in clock. With thanks brian
you can use any VOLTAGE FREE timer to opperate the boiler there are 2 ways you can install it
1 leave the old clock in and set it to 24 hour mode
fit an external voltage free switching clock , the swithing to the clock can be fitted to the thermostat connection on the board at the links CN4 remove the link, and connect the 2 wires in place of the link.
2 remove the old clock use the L N connections to feed the ext clock
and the other 2 wires from the old clock will be the switch connections from the new clock
dont forget most important VOLAGE FREE SWITCHING
dont forget as well this should come under part P for electrical so beware i would avise you to get an electrician to do it for you
mick
Thanks mick I wont be doing myself can you recomend make of external clock to ask for as have been asked to pick one up as spark just doing it when got chance can i download boiler guide with wiring diagram as not got manual with boileronce again thanks for help Brian
just tell your electrician to use voltage free and he can supply a suitable clock
go to www.ravenheat.co.uk follow the link into the website then on the side click on instalation manuals and you should find what you want in a printable version
Can recommend the Salus RT500RF. Its a 240 volt supply with a volt free switching option. Around £40-60 +vat and a doddle to fit, you only have to remove the 240 volt link on the receiver for it to work volt free. Used loads they are brill and wireless too.
