Hi there,
I've got a slightly confusing situation with a remote thermostat and an analogue time switch on a combi boiler. The boiler is in the loft so its a pain to adjust the time manually. It has one of the old style time switching clocks which I have set but apparently the boiler seems to still be running during the night. It's not my house so it's not quite as easy for me to check when its on and off. On the clock there is also a switch which can be set to "on", "off" or "auto". It had been set to "on" when installed which I guessed was why it was still on during the night, presumably because the thermostat was calling for heat. I tried switching to "auto" believing this would then mean it was on and off at the appropriate times, but I'm thinking that would mean it couldn't be switched on manually by adjusting the thermostat if it gets a bit nippy ?
Does that make sense ? and that its supposed to be left "on" but then just controlled purely by the thermostat ? or am I missing something. Like I say, its not my boiler so haven't got my head around the problem fully.
Thanks for any advice
