Timebond (Evo- Stick Impact Adheshive)
1 May 2008
Norfolk
I bought a tin of this stuff. It does not do what it says on the tin! Apparently it allows you to slide the two parts to be bonded slightly!!! No way!!!!
Instructions says: Wait 5-10 mins after applying glue to both parts, then bring both parts together. Doing it this way there is no way of sliding any part!
The trick is to slide the two parts to be glued immediately. This works fine with two pieces say 6" square. You try it with a 2 foot square pieces.
After the first part has glue applied to it, it has gone off by the time applying glue to the 2nd bit is finished!
Any comments/tips please?
