Dear experts,
I have a small problem with the central heating in the flat in that it works fine but in order for it to come automatically you need to turn on a hot water tap. this then forces the pilot light to flare up and start pumping heat into the radiators.
I am not sure why this isn't a problem for the hot water but it is a problem with the heating.
I should probably also mention that we have had plumber in to replace a wax capsule he also found it necessary to replace the pump.
Does anyone have any suggestions for a possible fix or solution
