All,
I've followed the wiring diagram below and wanted to check something with you:
When I switch on the light, the neon indicator on my double pole switch comes on (it's wall mounted, outside the bathroom). This is with my SFCU to the fan switched OFF.
If I turn the SFCU to the fan ON, the neon light goes OUT.
It seems to me as if I've got something wired in the wrong way around, as I would expect the neon light to stay off when the SFCU is off.
For clarity, I have assumed in the diagram the the top section of the DP light switch is the feed and that the bottom section is the load.
The switched live from my bathroom light is in the feed live connection on the switch, the feed neutral has the permanent live going to the JB (and eventually to the fan). The live from the bathroom light is wired into the live load connection and the switched live to the JB is in the neutral load.
It seems to work at the moment, but I get the feeling that the effect is that my the SFCU to the fan is wired the wrong way round - i.e. when the SFCU is OFF, the fan will come ON.
Can anyone offer any suggestions?
Thanks,
Rich
Thanks,
Rich
