We live in a traditional flat with an old style door entry system (buzzer box at the door and phone handsets in the flats).
The timer (that allows the service buzzer to work for the post man) on the entry system has stopped working and it needs replaced. It looks as if it is just like the sort of timer that you get on old hot water systems (clock dial that rotates and you push plastic pins in to fix the on/off times). Any idea where I can get a replacement timer??
I've tried B&Q and the only ones I could find were for 3 pin plug sockets for lamps or other appliances that need timers or electronic ones for central heating systems (which are quite expensive £50+). Found a few options at Screwfix which are lighting timers (digital with 7 day set up and various on/off options) - would this sort of thing be suitable (they only seem to cost £15-20)?
Cheers,
John
Cheers,
John
