Timer not working on boiler
16 Oct 2006
We've recently moved into a new house and had the boiler serviced which all went okay in the end - however on moving in we discovered the clock on the timer doesn't work. It's a Vokera Linea 726, with the mechanical clock. It just doesn't go round. Any ideas on how to fix it as we're either freezing at night or roasting? Thanks!
Will it come on if you move the little switch in the middle of the clock?
If its not turning round then its a new one i'm afraid.
I'm pleased to say I have actually checked that!! So looks like it's a new timer. Would you say it's a complicated job putting one in? Could I do it myself or should I call out someone?
Its an easy job as long as you are able to make sure that the boiler is isolated from the electricity before sticking your hands in.
That sounds sensible. I'll give it a go, then will probably have to call out someone later on! Let's hope not. Thanks for your help and speedy reply! :)
