Timer replacement (Randall)
3 Dec 2007
Leicestershire
Can you get a direct replacement for a Randall 102 timer? This is one of the older types & I was wondering if there is a "plug in" type of replacement?
You can still get them & replacement is easy. Turn off the power, on the bottom of the timer is a screw set in a recess, unscrew that & remove the cover off the bottom, pull the timer up off the backplate to remove. refitting is obviously the reverse of taking it off.
As keego says you can still get them ,you can also get a digital102e which also fits straight onto the existing back plate
The way plumbcentre are down stocking i doubt it . Do a search on tinternet
