Having been flushed with the success of the starter motor and crank pulley replacements and the dreaded fuel filter change, I'm considering attempting the timing belt swap. At a garage the timing belt change costs £500+, and, at the moment, there is a special offer on parts meaning that I can get the entire kit (inc water pump) for £85.
I've read through the procedure and it seems straight forward enough (I've done a few before), but I'm puzzled why you have to loosen the camshaft sprocket from it's shaft. The ones I've done before, you either lock the sprockets with a special tool or drill bit, or you mark the positions of the sprockets and make sure they don't move.
Is it really necessary to loosen the sprocket as it would make the job a lot harder and more scope to go wrong.
