- Joined
- 20 Apr 2016
- Messages
- 17
- Reaction score
- 0
- Country
I have recently fitted a 1200x800 stone resin shower tray as per the instructions which was 10mm ply and 15mm mortar mix. Its one of the sloping ones with a fair bit of meat to it
Half way into the job trying to level it up I realised the tray wasn't perfectly flat one of the corners, it wasn't out by much and only quite close to the corner but I was striving for perfection. After the hassle of changing it once already I decided to go ahead and lay it anyway and after testing it with water it all flows nicely.
About a week later when i'm finishing a few bits off I notice the corner that was a bit low has a hairline crack int he mortar about 6" from the end just under the shower tray and when i press on the corner of the shower tray the gap closes up, it must only be a few thou that it is moving.
Now I'm tempted to leave it as the rest of the tray is absolutely solid as a rock, and it is at the opposite end of the tray where you get in and out, and when the shower screen is up you won't even tread near that corner.
Has anybody else had anything similar or could give me some advice? Can I get away with it?
Thankyou.
Thankyou.
