I have a Studio Flat with electric heating, a water tank for hot water serving taps only. This works fine and hot water is good. Problem is a small leak from overflow pipe at base of water tank. The leak is in the joint between pipe and tank. I have tried using epoxy putty to fix the leak but it persists (it is very small and dries before it reaches another surface).
I applied the putty in a couple of stages - firstly around the joint but leak occured between tank and putty. Secondly roughened tank and leak now appears through putty.
I am loath to apply more putty as I am not sure this will fix the problem.
Any suggestions greatly appreciated.
Thanks,
Thanks,
