Tiny screws question
30 Dec 2018
Up North
IP cam, who ever built it, did so with a screw which was too short, it attaches the moving head, to the shaft which rotates it. I just need a longer screw, but with the same thread.
Measuring the major diameter of the thread (across the tops of the threads) I get 1.8mm. This table, suggests it must be a 1.8mm thread
-https://www.accu.co.uk/p/117-iso-metric-thread-dimensions
I bought a mixed set of glasses/watch screws, the largest of which was suggested to be a 2.5mm thread. Measuring the major diameter of these 2.5mm, I get 1.30mm, so too small, so how come they are described as 2.5mm?
I spent today, with the screw as a sample - trying a few watchmakers, jewellers, and computer repairers, trying to track down the screw I need, but so many send their items off for repair - so no luck there.
Surely if you know the diameter and the pitch then you can work out what the thread is? Did the mixed screws not contain any 1.8's? Is 1.8 a readily available size?
Is the screw, screwing through plastic or metal.
And is it a machine thread or self tapper type.
A tapped round metal shaft end, with two flats on it. The head which fits onto it has matching flats, is plastic, with a deeply recessed hole for the screw, which is a Philips, domed head machine screw..
Judging from micro screws on eBay, 1.8mm is not a usual size, all the listings Ive come across go from 1.6mm to 2.0mm
I wonder if these may work.....
I just got this sorted. It turned out to be a M2 after all. The major width, larger diameter across the thread measured 1.8mm. The table I checked, suggested 1.8mm should have been a M1.8 thread, and 2mm a M2. I couldn't find a source, for a M1.8 anywhere, so I risked buying a single M2 x 10mm length alan screw. Intending to trim the length down to the shorter length which was needed.
The M2 fitted perfectly, and I didn't even need to risk messing the thread up, by cutting it down - the hole was tapped all the way through and out the other side of the drive shaft.
Gotter wonder which doppy sod thought to specify a M2 screw only catching into the drive shaft by a couple of threads..
It may be just me but before I throw away any electronics I dismantle it and save the screws - and any interesting bits that might be useful.
Bet I would of had one to fit in my little pot of tiny screws.
We all have that tub of old screws/fittings/bolts etc our kids will just skip when we pop it.
Yep.
Spend a lifetime building up the "might come in handy", just for them to be thrown out.
Kids have all ready told me they will sell my tools when I pop off
