I'm replacing the suspended floor throughout the downstairs of my early-/mid-Victorian terrace (extensive rot and beetle activity), and the joists are a teeny-tiny 3.5" x 2.5". They're at ~40cm centres and the longest unsupported span between sleeper walls is ~130cm.
I can't lower the sleeper walls without re-routing the gas and CH pipework, and I can't raise the floor without causing height issues with the front and kitchen steps as well as the original Victorian skirting in the hallway, so simply replacing them with taller joists would be... problematic.
Where the floor hasn't rotted or been eaten away, there's no obvious sign of fatigue to the joists, so I assume it'd be fine to replace like-for-like?
