I'd never used an auger bit larger than 12mm until recently. Trying a 19mm one, I found it so powerfully pulling itself into the wood that it overwhelmed both my cordless and my corded drills, both grinding to a halt halfway through. Apart from anything else they were very uncontrollable. I have a pillar drill which might have aided control, but chuck to baseplate distance was too short for this drill. I assumed it was the design of the main part of the bit that created the strong pulling force. However I saw someone online recommending a pilot hole so that the screwed tip of the bit has nothing to bite into. Tried it - 6mm in my case - and it worked well and was easily controlled. So, it seems that the short screwed end of the bit is the part that pulls it so strongly into the material. Apologies if everybody knows this but I didn't and thought it might help others to let them know.
