We're replacing our existing suspended timber floor with a new solid floor. We plan to dig down to 485mm for the builder to build it up again in a couple of weeks.
The final floor build up will be;
150mm MOT 1
25mm Sand Blinding
DPM
150mm Concrete
100mm Insulation
60mm Screed
The existing void ranges from 80mm (where the joists sitting on the ground and were rotten!) to 550mm. The overall area is 60sqm.
I plan on hiring a micro digger and dumper that I can fit through the internal doors to make the work a little easier, but how do you guys recommend we tackle it?
I was thinking of pegging out in strips so we can measure depths and levels as we go, but is there a better way?
150mm MOT 1
25mm Sand Blinding
DPM
150mm Concrete
100mm Insulation
60mm Screed
