Can anyone give me some tips on plastering please?
I want to patch up my walls with filler then would like to skim with plaster.
When filling in holes in my walls, I use Filler or Patching Plaster. When I put these onto my wall, it sticks and stays stuck until I go over it again, 5 minutes later with a trowel, it peels and falls off the wall Why? This always happens every time I plaster – what am I doing wrong?
I've brush the walls down with water but this problem still happens. Should the walls be wet or dry before plastering? Should I make the mix wetter or dryer? Do I add anything to the mix?
Any tips?
Thank you.
Any tips?
Thank you.
