- Joined
- 31 Mar 2006
- Messages
- 223
- Reaction score
- 1
- Country
Hi all,
I have a small hallway about 3.5m long with varying widths between 1 and 2m. It's a very uneven shape.
It was carpeted and led onto 2 rooms with bare boards varnished with antique pine.
I had heard sanding a floor was a technically easy job, just unpleasant.
So I pulled up the carpet, rented a push-a-long sander and a little one for edges.
I spent a few hours sanding it down and thought it was ok. I varnished the floor but then realised I had done a really bad job
The surface has loads grooves in it and even the smooth bits have a different finish. Where the existing floor is slightly reflective and feels really smooth and coated, almost like plastic, what I have down feels and looks like stained wood.
I'd like to try again and get it right so I had a few questions:
1) Since the hall is small I found it very difficult to move the large sander around evenly. I think where I kept having to move or rotate it I caused the grooves. The boards run perpendicular to the length of the hall. How should I have used it?
2) Was the problem in the surface that I didn't use the fine sand paper for long enough?
3) How long should it take? Maybe I just didn't do it for long enough?
4) Is varnish the correct finishing product? Looking at it now, I'm not sure that varnish creates that plastic like finish. Or do I just need loads of coats?
Any other tips, or suggestions on how I can get this bit of floor as nice as the rest?
Cheers
Cheers
