- Joined
- 26 Nov 2007
- Messages
- 177
- Reaction score
- 0
- Country
Friends,
It has now come to the time when I shall soon be applying paint to newly plastered walls. With the help of yourselves I have selected paints and tools etc, I would now like some advice on the application of the paint.
I presume it is best to start with the ceiling and then move on to the walls. I have looked online, and have been advised to 'cut in' around the edges of the ceiling with a brush where it meets the walls and then apply the paint with a roller.
Considering the time that it wall take to go around the room and 'cut in' surely when I come to using the roller, the 'cut in' strip of paint will be dry. Is it OK to paint up to and over the 'cut in' part using the roller or alternatively, should I cut in and immediately apply the roller in the same area as I go (therefore rolling over freshly cut in paint).
Is it true that as I roll the roller, I should be rolling in an 'N' shape and then be filling in, in parallel lines over the unpainted N? Should I be making sure that when I use the roller that I partially repaint freshly wet paint from the previous roll i.e overlapping?
If the ceiling is to be white with magnolia walls, should I mask the bare plaster on the walls to prevent white paint getting on them when I cut in, or will the required magnolia on the walls cover this?
Sorry to be a pain in the backside but some help with the above really would be appreciated.
Kind Regards
Need Help 21
Kind Regards
Need Help 21
