We have a Creda condenser dryer which I think is about 8 years old, it's been used quite heavily in recent years due to the kids.
It is still running OK (still turns, heats fine etc) so I don't think anything's actually broken, but over time it seems to have got less efficient at drying - I seem to have to put the clothes in for a lot longer than in the past to get the same level of dryness. The ratio of "huge amounts of steam generated in utility room" to "clothes dryness" seems to be getting worse too. It also sometimes gets a bit of a "stale washing" smell (like when you leave stuff in the washer for too long) - though that could just be because my other half sometimes does exactly that...
I regularly de-fluff the fluff filter and fairly regularly rinse the condenser as it says in the instructions, and I've also cleaned out a lot of built-up fluff from the bit where the fluff filter goes in. Recently I also noticed there was a lot of wet fluff building up right inside the machine, at the end of the hole where the condenser goes (at the back), so I scraped as much of that out as I could reach as well.
Just wondering, are there any other things I can do or check to try and get it working a bit more like it used to? Thank you!
