Does anyone know if there is normally a isolation valve on the cold supply to a TMV in order to close the cold supply and basically bypass the TMV so no mixing occurs. Even at its maximum setting, around 48degC, the hot water temperature is to low for the owner of the house. The mixing valve was fitted on the hot supply to a bathroom in a large house.
Cheers
Cheers
