in a TN-S earthing system, when you have a supply going via armoured cable to a shed attached to house and that shed has a metal pipe which is in contact with earth
This pipe is connected to the armoured connector of the cable - is this sufficient equipotential bonding. Circuit has RCD
Just want to check set up is correct - recently moved in
Now theory questions
Should you have a seperate earth rod? and if you do - would you connect this to the armoured cable and ultimately to the supply earth.
Jason - your statement on earthed tools - does that apply to any external tool with any earth system - or just PME
