Hi all, new to the forum and have a question for you
While adding some sockets to a conservatory and locking off the CU I observed the main earth comming off the supply sheath and assumed a TN-S, however the earth cable from the sheath then goes into the suppliers cut out box with another earth comming out and attaching to the MET block on the wall TN-C-S. Any one seen similar?
I have a feeling that the whole setup has been interfered with by a DIY'er as the tails going into the meter have about 4mm of copper conductor showing and the CU wiring is a mess.
