To double glaze porch or not
4 Jan 2011
Perthshire
Hi.
I currently have a 3m x 2m ( approx) porch at the rear of my house. It is the main entry / exit of the house. It is fully singled glazed and the windows are about 25 to 30 years old and in reasonable condition, but needing a paint. I do not heat the porch. Once through the porch you then enter the kitchen. The only window in the kitchen is an older wooden framed double glazed unit which looks into the porch. The top opening part of this window does not fit well. The rest of the house has upvc doubled glazed windows which are in good condition.
I would like to know if it would be worthwhile replacing the porch windows to double glazed units to try and help the cold draughts that come into the kitchen. At the same time I would replace the wooden porch door as it has a couple of splits in it which let in a little water if the wind is right. I would prefer the look of timber framed windows but price will probably decide.
I know that as I don't heat the porch directly apart from what heat gets there when the kitchen door is open, that financially it won't add up. Priority here, however is to help the temperature in the rest of the house. If the porch was to be a bit less cold in the winter then that would help.
Perhaps I should just replace the kitchen window and door to something that fits better.
Dave
