As you can see I am building a step with new railway sleepers. The garden, even after I've levelled it a bit, will still slope towards the sleepers, and because of this I'm wondering whether or not I need to put a drain in so as to not put too much strain on the sleeper wall. As I see it I have three options: -
1. Leave it and just fill the void with soil
2. Just put gravel behind the sleepers ans hope that will do
3. Put in some perofrated pipe behind the sleepers to take away the water.
I only moved here in August so don't know how (if at all) waterlogged that garden gets when it's all settled.
Other hurldes I need to overcome if I'm going to drain is, as you may be able to see are: -
1. As you look at the sleepers I can drain the left hand side away no problem as that leeds to a communual grassed area in the corner of my garden.
2. But trying to do the same on the right hand side won't work as there is nowhere for the water to go.
a. Do I need to bother?
b. If so how can I drain the right hand side?
Cheers
