- Joined
- 13 Dec 2007
- Messages
- 4,009
- Reaction score
- 661
- Country
And people ask why I stopped working for Warmfront
Or another way of putting it... Ask people why I won't get involved with Warmfront.
Ever heard the phrase "beggars can't be choosers"? You are a rogue customer and not someone I'd like to work for; You invite a professional in (at the taxpayers expense) and then question everything he does, (he has told you the truth) and look for anyway not to pay him.
I hope you get your comeuppance sooner rather than later.
Read it and weep
Installation
Over the past few years, TRV installation has become even easier. Previously, flow direction through a valve was all-important and installers needed to check directional markings on the valve body to ensure correct fitting. The consequence of incorrect installation was the likelihood of water-hammer in the system.
Flow temperature dependency
In the UK, normal practice has been to install TRVs in the flow with the sensor head vertically above the valve.
While this does not prevent the valve working, it may not permit best control of room temperature. Heat rising from the valve and pipe work below, and from the nearby radiator itself, can cause the TRV to shut prematurely several degrees before the room reaches its set temperature.
This situation can be likened to siting a wall thermostat directly above a radiator; something no experienced heating installer would ever allow.
By installing a TRV with its sensor head horizontally away from the radiator at the flow connection, this problem is overcome and room temperature will be controlled very accurately. In the case of Danfoss radiator thermostats, which are liquid-filled, temperature monitoring occurs at the farthest point from the valve body and, typically, set room temperatures are maintained accurate to within 0.9°C.
Where horizontal installation in the flow is not practical, then fitting TRVs on the return is an acceptable alternative. Here, even if fitted vertically, room temperatures could be held to within 1.8°C.
http://danfoss-randall.co.uk/xxnewsx/bc9b4d5a-bdb9-4d40-9691-43abf6a67fdf.html[/QUOTE]
What does that prove apart from the fact you are a very petty little man?
Power flushing is what GW told me and just draining the system a couple of times is totally inadequate. I’m not a plumber, but I am a qualified engineer and know when the wools being pulled. There could well be other suitable flushing methods but best stick with what the manufacturer stipulates I say.
Once again you are showing your ignorance of the Warmfront scheme and haven't bothered to read what the OP said earlier. He has been granted the £300 Rebate, not the £3,500 Grant.If you are a qualified engineer then one would expect that you would be earning a reasonable salary of perhaps £30k-£70k and would not be in receipt of any grant aid which is targeted at the needy!
I agree that its unfair to charge the installer an admin fee of £50 for processing the grand voucher. However the installer is aware of this before he signs up for the scheme and, as has been pointed out by others, the installer can easily recoup this by upping his cost.I would expect any qualified engineer to be reasonably well off and if over 60 then not to be chasing small grants and then getting very annoyed with the installer when they point out that the £300 grant is only paid to the installer at £250.
To my way of thinking a grant paid at £250 is a £250 grant!
You are partly correct. The installer has to register with Warmfront to take part in the Rebate scheme, but that's as far as it goes. An installer can be registered for the £300 Rebate scheme but not registered for the £3,500 Grant. Unlike the Grant scheme, Warmfront has no say in the make of boiler, materials used, how the work is carried out etc or the actual cost of the installation. Those matters are determined by the customer and installer.I suspect that there is a further "catch" and to use the £250 grant it will be necessary to only use an installer who is registered with Warmfront.
The customer receives a £300 voucher from Warmfront which he gives to the installer. The installer sends it back to Warmfront, who sends him £250.Warmfront
Confirmed with Warmfront (3rd time) the customer gets the FULL £300 and the INSTALLER pays the admin fee.
Warmfront’s Statement not mine
Who has said anything different?TRV’s
Bi directional is to counter act water hammer.
Manufacturers statement not mine
Can you post a link please.Temperature control IS compromised if mounted incorrectly
You're an expert on cleaning systems?System Flushing
Statement -draining the system a couple of times will clean it - WRONG
