To keep, or not MMPEK
30 Dec 2018
Up North
I'm in the midst of sorting out my HP laptop, which died some while ago, due to HDD failure, plus some other issue, which resolved itself..
Original HDD was a WD Blue 1Tb + a M10 MEMPEK1J016GAH 16Gb SDD stick, it was reasonably fast. I got it going with an old slow Toshiba 1Gb, but I am now going to replace the Tosh, with an SDD sata III, 6Gb/s drive. The question is, should I keep the MEMPEK, or not, for best speed?
The SATA SSD is still going to be slower. At 6Gb/s, it's about 600MB/s max transfer speed, if the laptop and SSD can sustain that.
The Optane drive has a maximum transfer speed of 800MB/s.
Its use as a cache may not make a big difference, but it probably won't cause any harm. And it's not much use anywhere else, as Intel has killed off Optane memory.
You can always try first without it?
