Another query,,
A light switch has to be moved from inside room to outside (ceiling pull switch not an option). New position is as if you pushed the existing switch and your hand carried thru to other (out)side. Sliding door is reason
What is the correct procedure for doing this?
Is it...
Place pattress box and switch in other side of wall, blank plate on original side (I assume plastering over not allowed). What is the legal way to run the cable and make the new connection to the switch now on the other side of the wall??
Is it...
