I recently bought my first house (hence this being my first post) and have started to tackle the first room, the lounge. The whole house has been recently painted by the previous owner, but the visible border under the paint, plus a few other things made me want to redecorate.
The original idea was to remove the painted wallpaper and to re-paint straight onto the wall. However, after removing three layers of paper, a border, plus a bottom-half which seemed to have been applied with PVA, the state of the walls was not pretty.
Aside from the many gouges I had made in the plasterboard with the scraper trying to remove the impossibly glued paper, there were millions of holes, rawl plugs (with filler over them!) and one or two fist-sized gaps. This made me consider re-boarding the entire room (three external walls and one stud wall).
Another factor is the amount of cabling I want to hide in the walls for the A/V setup (sky cable, speaker cables, power, projector feed, etc)... Re-boarding would make this task a lot easier. However, having considered the extra cost and work involved, I took the decision just to remove the plasterboard from the stud wall (and glad I did as I found old tongue & groove wood panelling, and a door - all boarded over!).
Having since removed all the skirting boards, I'm again undecided as to whether or not to re-board the remaining walls.. mainly because there are a large number of fair-sized holes behind where the skirting used to be.
So my question is, given the situation, should I just rip it all out back to the breeze-block and start again? Or is this easily salvageable?
