I'm looking to install a macerator in an underground room. I need to pump the waste up to a 4" soil pipe at ceiling level but, because of ceiling joists and the position of the existing soil pipe, I will struggle to do my vertical run first, as I know you are supposed to do. Running the horizontal waste pipe to a point underneath the soil pipe, and then running vertically will be a much easier installation.
I need to run 3m horizontal and then 2.5m vertical.
Is this a good idea? Or even a vaguely acceptable idea?
Failing that, is a diagonal run a completely ridiculous idea?
