toilet ballcock valve
23 Mar 2005
i need to replace my valve on the toilet and would like some help on what kind of valve l could get which is adjustable on the thread length if there is any..
It is a bottom entry valve l need and as there is no play for the inlet supply pipe if l get a valve with a shorter thread length than the one l have on at the moment (if l cannot get one the same thread length) it will not connect to the inlet connection. so l wondered if there is a valve out there that is adjustable for the thread length as l know there is some that are adjustable for the height..
With a bottom connection, yes.
What's the thread length on the existing valve?
Will a flexi tap 15xx1/2x300 work with a fibre washer put in both ends..
The 15mm end is a compression joint, nut and olive.
Are you talking about removing the nut and olive (leaving a male 1/2" thread) and putting that into the existing swivel connector?
Surely, there's not enough room to do that?
