The plastic pipe coming from our toilet runs horizontally into an old (cast iron?) soil stack.
It's peeing water from the connection.
THe water is going into next door's drive so I'm reluctant to leave it over the weekend.
I only noticed because the toilet wouldn't flush, I managed to unblock it with some plunging but now it's gurgling.
Could it be that a blockage in the drain is causing pressure, and that is making the joint weep?
If so, will unblocking the drain allow the joint to settle down - or does it need replacing?
Ballpark for a proper repair to the joint?
Would really appreciate any answers before I call a plumber, on a saturday
Edit: lifted outside drain cover, no water backed up there.
