i have a newish 2007 toilet flush - purchased through MFI
which has a push button flash - which is attached to a cord that then raises a circular tube to flush the toilet
it looks like the cable is not lifting the circular assembly, i can see the mechanism and hows its all put together at the button , and that is working OK with a pivot that the push bar moves which than moves the cable
BUT its not moving that the other end in the water , section to lift the column
- not sure if the cable has simply just come off a socket or if its broken somewhere or the plastic lift is broken at all
any diagrams , part numbers or how to repair would be appreciated please
I can take a picture tomorrow (saturday) and link if that would help at all
the cistern is a plastic assembly thats fitted inside a cupboard type structure - so not the cistern that is fitted in a self contained assembly - its inside the woodern framework and quite a slimline style
