Hi all, I've got a new-ish cistern with a double button on top for small or large flush. (Eventually I figured out how to get lid off - you press the small flush button then you can lever t'other one out then remove small one and there's a screw) Anyway the refill doesn't work. There is a float like an upside-down ice-cream cone which pushes a lever against a valve. This is held by a screw-fitting ring. If you do the ring up tightly the valve shuts when the water level comes up, but the refill rate is very very slow. A bit looser with the ring and it fills quicker but the valve doesn't get shut off by the float/water level. It's not really useable 'cos the fill rate is so low the water just leaks past the bell and into the pan - I guess it relies on a bit of pressure to seal it. (Got another toilet!) I would be grateful for any ideas. Thanks in advance. - Terry.
