So, just fitted a new toilet, close coupled cistern to pan. Allseemed good until approx 24 hrs later.
Found a small leak from the righthand side plastic bolt that holds the cistern onto the pan. It is having a slight drip from underneath. I have had the bolt out and the dome shaped rubber washer, cleaned it, loosened the other side and really tightened this side, still the same, I have loosened it off, no improvement.
Thought I had it sorted last night, it went approx 15 hours with no leak, then it started, possibly after toilet flush. Could intake of cold water have caused rubber washer to flexi?
So I have now removed it, dried it and applied silicon sealant to the washer and the bolt, have I done right. Will leave it dry now until sealant sets.
Any other ideas PLEASE. The plastic bolts with wing nuts go all the way through the cistern.
