We have just moved into a flat and the toilet doesn't work! I have done a bit of research on the internet, but because I am not a typical DIY person, I'm still clueless about what I should do.
I have checked the inlet pipe and turned the valve to the left. There doesn't appear to be any water rushing into the ballcock assembly at all. I haven't checked to see whether the filter in the ballcock assembly is clogged up, because I am unable to get to it without first dismantling it.
Basically you have to keep filling up the toilet cistern after every time you flush it. Is there any easy way of fixing this?
Any help would be much appreciated!
