Toilet Concealed Flush-Suggestions please.
27 Jan 2008
Yorkshire
Currently have the above with a Fluidmaster Valve & a Ideal Standard Flush Plate .I replaced the valve as the flush is quite difficult to operate & also replaced the air pipe but the problem remains has anyone a recommendation to replace the (9"x6") Flush panel or should I try a different Valve ? -Thanks in advance.
Sometimes, just sometimes cutting 5mm off the tube where it joins the push button bellows sorts it out or new buttons can be found on fleabay.
