Help please, this is a first time installation! As in the photo we have what looks like a 110mm lead pipe leading to the soil stack.
View media item 90189
The toilet will be 700mm away at right angles (not backing straight on). We want to get the soil pipe against the green wall. Can you help with ideal fittings as I fear my plan will result in too many connections with the potential to leak. Also, do the fins of the pan connector go straight into the sawn soil pipe or should the be a socket type connection?
a. 110mm soil to drain adaptor
b. 2 x 102 degree bends to create S bend
c. Length of 110mm soil pipe cut to size.
d. Flexible pan connector with jubilee clip for back to wall toilet.
View media item 90192
Thanks for any advice.
