Toilet doesn't flush unless lever pumped
24 Oct 2023
Hi all
Moved into this house not long ago and the downstairs toilet always needed a bit more force to get it to flush
Over the last year this has gone from a bit more force to having to pump the handle
The old lever looked a bit tired so I replaced that (see pictured) and I've tried it in different positions to try and get the most "purchase" from the flush, no joy
Any advice/ideas appreciated
Video in link - https://go.screenpal.com/watch/cZffFwVsbF4
Many Thanks
The plastic membrane which acts as a one-way valve inside the flush body is likely knackered. Time to replace the flush.
Siphon is knackered, probably just the washer, but as it's got to come out the cistern to replace the washer, I'd take the opportunity to replace it with a 2 part siphon, and make future maintenance easy, unless you're planning to change the entire WC in the near future.
Avoid the temptation to replace it with Flush Valve, they are poxy affairs and vastly inferior to a Siphon.
Just to add a little more detail - a 2 part siphon allows the siphon part to be removed from the outlet flush pipe at the base of the cistern, so you can easily replace the membrane in future without having to take the cistern apart from the toilet bowl.
And I agree, siphons remain much superior to any of the new flush mechanisms.
