Toilet Drain - 90 Degree
16 Aug 2004
Hi
I need to connect on to a new drain that is at 90 degrees from the outlet of a new toilet position.
The drain is a fair distance away, maybe 12 metres, but since I don't want to dig right across an existing conservatory can I connect with a 90 degree bend?
Maybe a long turn elbow?
D
This will all be below ground. I had some drainage guys out in a bunch of drains including a manhole that has been put in ready for the new downstairs loo to connect to. So there will be a drain going (underground) from the new bathroom to the manhole. They are at 90 degrees to each other though and so my question is whether I can go with a 90 degree bend (which would give me the shortest dig) or whether I had to for example go with 2 x 45 degree bends instead? Doing the latter means a longer dig through an existing conservatory floor.
