Hi Guys
I am struggling to find a toilet extractor fan that meets the following:
- Good quality
-100mm wide (easy)
- low voltage 12V
- kicks off when light switch is turned on
- has an override timer
- has humidity sensor so it can also kick off on its own when room humidity is greater than X%
any ideas?
So far can find light switched ones, but the humidistat ones dont work with the switches, they just work by monitoring humidity levels..
- Good quality
-100mm wide (easy)
- low voltage 12V
any ideas?
