Having tiled the bathroom floor and lifted the toilet up by about 15mm, the copper feed pipe no longer fits securely onto the plastic threaded pipe going into the cistern. It was at a very odd angle when I initially detached it.
When detached the feed pipe naturally sits about 1/2 inch off the plastic pipe so you have to really pull the copper feed pipe into place before you screw it on.
I'm a plumbing novice.
Is there some kind of flexible pipe I can get to sit between the two, or is there an alternative solution i'm not aware of? Its leaking every time I turn the water on.
