Hi everyone.
I'm going to be replacing the filler valve in the loo (Not an issue). Im going to replace an old failed iso valve that sits between the current copper and filler.
Im going to cut back some of the old copper and use a flexi.
1) Would you use a compression or push-fit flexi on the copper.
2) All the copper piping has been coated in gloss, if using either type, can i just go straight over the gloss, or will I have to remove the gloss? (how?)
Thanks..
Thanks..
