can anybody help?when i flush the toilet it makes a whirring sound,it sounds like the syphon?is it east to fix,somebody told me you can replace the diaphram at the bottom of the syphon if it has gone?thanks,jointy
As above, if it was a syphon problem it would usually be a flushing issue. It could be the fill valve or even another valve not connected with the toilet. Check all valves and taps aswell.
